[mapguide-users] mapguide-rest setup issue with Mpaguide 2.5.2
Rémy Gourrat
rgourrat at ag-carto.fr
Thu Nov 3 05:04:24 PDT 2016
I try to setup mapguide-rest with MapGuide 2.5.2 which use PHP 3.3.8,
I read that theorically mapguide-rest is running with a mapguide supporting PHP 3.3 and upper
Jackie said that :
"mapguide-rest has been tested on MapGuide Open Source 2.6.
It should theoretically work on any installation of MapGuide Open Source or AIMS that includes PHP 5.3 or newer."
When I execute composer install I see lot of problems of dependencies.
The only solution is to setup another PHP outside mapguide 2.5.2 (I can't migrate in 2.5.6) ?
Or can I get an old mapguide-rest 2.5.2 compatible ?
Thanks for your advice
Rémy
When I execute composer install, I see that :
C:\Program Files\OSGeo\MapGuide\Web\www\rest>composer install
Your version of PHP, 5.3.8-Win64, is affected by CVE-2013-6420 and cannot safely perform certificate validation, we strongly suggest you upgrade.
Loading composer repositories with package information
Installing dependencies (including require-dev) from lock file
Your requirements could not be resolved to an installable set of packages.
Problem 1
- Installation request for brianium/paratest dev-master -> satisfiable by brianium/paratest[dev-master].
- brianium/paratest dev-master requires php >=5.5.11 -> your PHP version (5.3.8) does not satisfy that requirement.
Problem 2
- Installation request for phpdocumentor/reflection-common 1.0 -> satisfiable by phpdocumentor/reflection-common[1.0].
- phpdocumentor/reflection-common 1.0 requires php >=5.5 -> your PHP version (5.3.8) does not satisfy that requirement.
Problem 3
- Installation request for phpdocumentor/reflection-docblock 3.1.1 -> satisfiable by phpdocumentor/reflection-docblock[3.1.1].
- phpdocumentor/reflection-docblock 3.1.1 requires php >=5.5 -> your PHP version (5.3.8) does not satisfy that requirement.
Problem 4
- Installation request for phpdocumentor/type-resolver 0.2 -> satisfiable by phpdocumentor/type-resolver[0.2].
- phpdocumentor/type-resolver 0.2 requires php >=5.5 -> your PHP version (5.3.8) does not satisfy that requirement.
Problem 5
- Installation request for symfony/console v3.1.5 -> satisfiable by symfony/console[v3.1.5].
- symfony/console v3.1.5 requires php >=5.5.9 -> your PHP version (5.3.8) does not satisfy that requirement.
Problem 6
- Installation request for symfony/debug v3.1.5 -> satisfiable by symfony/debug[v3.1.5].
- symfony/debug v3.1.5 requires php >=5.5.9 -> your PHP version (5.3.8) does not satisfy that requirement.
Problem 7
- Installation request for symfony/finder v3.1.5 -> satisfiable by symfony/finder[v3.1.5].
- symfony/finder v3.1.5 requires php >=5.5.9 -> your PHP version (5.3.8) does not satisfy that requirement.
Problem 8
- Installation request for symfony/process v3.1.5 -> satisfiable by symfony/process[v3.1.5].
- symfony/process v3.1.5 requires php >=5.5.9 -> your PHP version (5.3.8) does not satisfy that requirement.
Problem 9
- Installation request for symfony/yaml v3.1.5 -> satisfiable by symfony/yaml[v3.1.5].
- symfony/yaml v3.1.5 requires php >=5.5.9 -> your PHP version (5.3.8) does not satisfy that requirement.
Problem 10
- Installation request for zircote/swagger-php 2.0.7 -> satisfiable by zircote/swagger-php[2.0.7].
- zircote/swagger-php 2.0.7 requires php >=5.4.0 -> your PHP version (5.3.8) does not satisfy that requirement.
Problem 11
- phpunit/phpunit 4.8.27 requires symfony/yaml ~2.1|~3.0 -> satisfiable by symfony/yaml[v3.1.5].
- Installation request for phpunit/phpunit 4.8.27 -> satisfiable by phpunit/phpunit[4.8.27].
AG-Carto - Bayonne
View this message in context: http://osgeo-org.1560.x6.nabble.com/mapguide-rest-setup-issue-with-Mpaguide-2-5-2-tp5294155.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20161103/33d49c77/attachment.html>
