[mapguide-users] Bug: CreateRuntimeMap returns scalerange with „Null“ when using Raster or WMS-layers in Map
Jackie Ng jumpinjackie at gmail.com
Thu Oct 20 16:43:36 PDT 2016
Ok this is something that may need a bit of discussion. This is not only a
bug in the CREATERUNTIMEMAP implementation, it's also a bug in the spec (xml
schema).
A client application like Fusion tests for the absence of the ScaleRange
property in order to determine if it's a non-vector layer. If I fix this
"bug", the raster layers will have a scale range, but there will still be no
practical way to differentiate between a vector layer and a raster layer.
This is because there is nothing in the runtime map schema that tells us
whether a layer is a vector/raster/drawing layer.
If I fix the implementation, if you need to test for the layer's type you
would have to test for the following:
 - Drawing: The FeatureSource is a resource id ending with "DrawingSource"
 - Raster: The ScaleRange is not null, but it only has a minscale/maxscale
set, the FeatureStyle will be an empty array (the XML schema prevents us
from setting this to null)
 - Vector: None of the above.
This is the only way I can see this "problem" being fixed without doing a
schema revision. Does this sound acceptable?
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Bug-CreateRuntimeMap-returns-scalerange-with-Null-when-using-Raster-or-WMS-layers-in-Map-tp5291469p5291797.html
