[mapguide-users] Draw polygon using Javascript API?
BMason
masonb12 at telus.net
Mon Oct 31 14:17:15 PDT 2016
Is it possible to use mapguide-rest to append/ draw new points, lines and
polygons by digitizing in mapguide to an existing shapefile or SDF file on
the server? If it is possible, is easy to manage the coding for this
process when upgrading to a new version of mapguide, for example?
Hopefully, working with shapefiles and SDF files will be a lot easier to
manage than using SQL server and oracle spatial and phprunner. thanks
View this message in context: http://osgeo-org.1560.x6.nabble.com/Draw-polygon-using-Javascript-API-tp5292596p5293700.html
