[mapguide-users] MapGuide 3.0 installer stuck at "IIS Configuration Settings"
Hans Milling hm at geograf.dk
Wed Sep 21 03:42:48 PDT 2016
I tried to InstantSetup bundle. That works more or less, until I try to
create a new FeatureSource, Map, Layer or anything else in Maestro. I get
the following error (ISAPI seems to be installed correctly in IIS by the
InstantSetup):
System.Exception: The remote server returned an error: (559)
MgFileIoException.:
- IsapiAgent.HttpExtensionProc() line 211 file IsapiAgent.cpp
- IsapiPostParser.Parse() line 199 file IsapiPostParser.cpp
- MgFileUtil.GenerateTempFileName() line 1123 file
c:\working\build_area\mapguide\3.1.0\x64\mgdev\common\foundation\System/FileUtil.cpp
- MgFileUtil.GetTempPath() line 1016 file
- MgFileUtil.CreateDirectory() line 427 file
- MgFileUtil.MkDir() line 454 file
 ---> System.Net.WebException: The remote server returned an error: (559)
MgFileIoException.
   at System.Net.HttpWebRequest.GetResponse()
   at
OSGeo.MapGuide.MaestroAPI.HttpServerConnection.SetResourceXmlData(String
resourceid, Stream content, Stream header) in
c:\working\JenkinsCI\home\slave_win\jobs\Maestro
trunk\workspace\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:line
651
   --- End of inner exception stack trace ---
   at
OSGeo.MapGuide.MaestroAPI.PlatformConnectionBase.SaveResource(IResource
resource) in c:\working\JenkinsCI\home\slave_win\jobs\Maestro
trunk\workspace\OSGeo.MapGuide.MaestroAPI\PlatformConnectionBase.cs:line
1274
   at
OSGeo.MapGuide.MaestroAPI.HttpServerConnection.OSGeo.MapGuide.MaestroAPI.Services.IResourceService.SaveResource(IResource
   at Maestro.Base.Commands.NewItemCommand.Run() in
trunk\workspace\Maestro.Base\Commands\NewItemCommand.cs:line 60
   at ICSharpCode.Core.WinForms.MenuCommand.OnClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e,
ToolStripItemEventType met)
   at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e,
   at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons
button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ToolStrip.WndProc(Message& m)
   at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
IntPtr wparam, IntPtr lparam)
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-3-0-installer-stuck-at-IIS-Configuration-Settings-tp5287047p5287069.html
