[mapguide-users] MapGuide 3.0 installer stuck at "IIS Configuration Settings"
Jackie Ng jumpinjackie at gmail.com
Wed Sep 21 07:25:52 PDT 2016
Addressing the original issue:
It's the IIS version check. Since IIS on Windows 10 is v10, its version
string is "10", which fails the IISVERSIONMAJOR >= "#7" launch condition to
proceed to the next screen. This probably slipped under may radar as the
last time I tested this was against Windows 10 preview builds which probably
hadn't bumped IIS to v10.
I'll remove this version check as the versions of Windows we support will
have IIS >= 7 already.
https://trac.osgeo.org/mapguide/ticket/2742
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-3-0-installer-stuck-at-IIS-Configuration-Settings-tp5287047p5287124.html
