[mapguide-users] Maestro API 6 - How to convert xml to ILayerDefinition
Hans Milling
hm at geograf.dk
Thu Sep 22 06:14:38 PDT 2016
I might have found a way to do it with Maestro API 6. However I need to solve
the 1000+ compiler errors after swapping the API, before I can confirm that
it works:
ILayerDefinition ldef =
(ILayerDefinition)ObjectFactory.Deserialize("ILayerDefinition",
file.GetInputStream(e));
As a side note (to Jackie). It would be great if the "string resourceType"
parameter were exchanged with the ResourceTypes enum, since I have
absolutely no clue what to write in that string field.
Best regards
Hans Milling...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Maestro-API-6-How-to-convert-xml-to-ILayerDefinition-tp5287254p5287290.html
