[mapguide-users] Introducing mapguide-react-layout: A modern viewer for MapGuide
GeorgesK georges.kacou at gmail.com
Wed Sep 28 07:02:40 PDT 2016
To Kajar,
Did you download the viewer.zip from the Releases section ? If you download
the master(.zip) file, it will not work, since it doesn't have the
dist/viewer.js file.
Second, do you use a specific coordinate system ? If yes, check this url :
https://github.com/jumpinjackie/mapguide-react-layout/blob/master/KNOWN_ISSUES.md#viewer
Hope this helps.
Georges
View this message in context: http://osgeo-org.1560.x6.nabble.com/Introducing-mapguide-react-layout-A-modern-viewer-for-MapGuide-tp5288019p5288247.html
