[mapguide-users] IronPython: strange behaviour with DictReader
kdm
koen.de.munter at geoit.be
Thu Aug 17 00:35:40 PDT 2017
When I execute the code snippet below line by line, I get the results you
should expect: every row is printed out.
However, when I execute exactly the same code by running it from a PY-file,
nothing happens.
It goes wrong when looping through the DictReader object.
Is this a known IronPython issue?
By means of a CSV file I'd like to generate some maps.
View this message in context: http://osgeo-org.1560.x6.nabble.com/IronPython-strange-behaviour-with-DictReader-tp5331666.html
