[mapguide-users] MapGuide 3.1 Add or edit the map on Runtime
Mark Volz (LeapCAD) mark at leap-cad.com
Wed Dec 20 00:12:26 PST 2017
For those who are upgrading from a 2.x version of MapGuide and can no longer add / edit layers or basically manipulate the map during runtime please read this post around the changes made to the mgmap constructor.
http://themapguyde.blogspot.com.au/2013/03/mapguide-tidbits-mgmap-constructor.html
Basically if your old code has something like:
$map = new MgMap();
$map->Open($resourceService,$mapName);
Then you are going to have to change the way you get a handle on the current map. A very simple example can be found in \mapguide\web\www\<your lang>samples\change_layers_Via_dom.xyz (if you remembered to install the samples).
Hope this helps.
Mark
