[mapguide-users] unable to logon Mapguide : ACE.dll failed
Maximino Roza Candas
wis at distecable.com
Mon Feb 6 02:13:24 PST 2017
Hi Remy
I've a similar issue a couple of months ago,
I've installed 3.0.0 but I wanted to change it to 2.5.2 for
compatibility.
Then I’ve found that for running again 2.5.2 I needed to install it
in a different path of the previous 3.0.
In other words :
If you've installed 3.0.0 in c:/xxxx/mapguide.
You need put 2.5.2 in another path : c:/xxxx/mapguide2 ; not in the
same like the previous that obviously also should be uninstalled.
That it works for me.
Hope it helps.
Max
El 06/02/17 a las 10:36, Rémy Gourrat escribió:
> Hi Jackie,
> I check it and check it again : ACE.dll is in the path.
> I uninstall many times iis and mapguide 2.5.2, each time it was the
> sames messages in maestro/mapadmin and windows event log.
> I tried with mapguide 2.6.1, sames messages, i tried with instant
> setup for 2.5.2 and 2.6.1, sames messages.
> Finally, i tried with 3.0.0 and 3.1.0 and it’s running !!
> I think this is an issue with WINDOWS 8.1 and 2.5.2 and 2.6.1.
> I need to install mapguide 2.5.2 for application compatibility.
> someone have an idea to workaround this issue ?
> Rémy
> AG-Carto - Bayonne
> View this message in context: RE: unable to logon Mapguide : ACE.dll
> failed
> <http://osgeo-org.1560.x6.nabble.com/unable-to-logon-Mapguide-ACE-dll-failed-tp5306170p5306444.html>
> Sent from the MapGuide Users mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html> at
> Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
/"A World Without Limits"/
www.DisteCable.com <http://www.distecable.com>
Maximino Roza Candás
Data Base & I+D Manager
*DisteCable S.L.
*Tel: +34 985 362 626
Fax: +34 985 132 122
Mov: +34 678 473 239
Aviso Legal: www.DisteCable.com/Avisolegal
<http://www.distecable.com/avisolegal.html>Disclaimer:
www.DisteCable.com/Disclaimer
<http://www.distecable.com/disclaimer.html>Avertissement Légal:
www.DisteCable.com/Avertissement
<http://www.distecable.com/avertissement.html>No imprimas este correo si
no es necesario. RESPETA EL MEDIO AMBIENTE
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20170206/66fa5156/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20170206/66fa5156/attachment.png>
