[mapguide-users] MapGuide Maestro 6.0M6 available
RenoSun
renolionheart at gmail.com
Mon Feb 6 10:04:39 PST 2017
Non-modal map previews is not working if the map has transparent background
colors.
*Control does not support transparent background colors.*
/System.ArgumentException: Control does not support transparent background
colors.
at System.Windows.Forms.Control.set_BackColor(Color value)
at Maestro.MapViewer.MapViewer.InitViewerFromMap(Nullable`1 initialScale)
in C:\projects\mapguide-maestro\Maestro.MapViewer\MapViewer.cs:line 1155
at Maestro.MapViewer.MapViewer.LoadMap(RuntimeMap map) in
C:\projects\mapguide-maestro\Maestro.MapViewer\MapViewer.cs:line 1138
at Maestro.Editors.Preview.MapPreviewViewContent.OnLoad(EventArgs e) in
C:\projects\mapguide-maestro\Maestro.Editors\Preview\MapPreviewViewContent.cs:line
73
at System.Windows.Forms.UserControl.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.SetVisibleCore(Boolean value)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at WeifenLuo.WinFormsUI.Docking.DockContentHandler.SetVisible()
at WeifenLuo.WinFormsUI.Docking.DockPane.set_ActiveContent(IDockContent
value)
at WeifenLuo.WinFormsUI.Docking.DockContentHandler.Activate()
at WeifenLuo.WinFormsUI.Docking.DockContentHandler.Show(DockPanel
dockPanel, DockState dockState)
dockPanel)
at WeifenLuo.WinFormsUI.Docking.DockContent.Show(DockPanel dockPanel)
at Maestro.Shared.UI.WorkbenchBase.ShowContent(IViewContent vc) in
C:\projects\mapguide-maestro\Maestro.Shared.UI\WorkbenchBase.cs:line 410
at Maestro.Shared.UI.ViewContentManagerBase.OpenContent[T](String title,
String description, ViewRegion region, CreateFunc`1 method) in
C:\projects\mapguide-maestro\Maestro.Shared.UI\ViewContentManagerBase.cs:line
229
at Maestro.Shared.UI.ViewContentManagerBase.OpenContent[T](ViewRegion
164
at
Maestro.Editors.Preview.LocalMapPreviewer.<>c__DisplayClass10_0.<Preview>b__1(Object
obj, Exception ex) in
C:\projects\mapguide-maestro\Maestro.Editors\Preview\LocalMapPreviewer.cs:line
172
at Maestro.Shared.UI.BusyWaitDialog.Run(String message, BusyWaitDelegate
action, Action`2 onComplete, Boolean bPreserveThreadCulture) in
C:\projects\mapguide-maestro\Maestro.Shared.UI\BusyWaitDialog.cs:line 103
at Maestro.Editors.Preview.LocalMapPreviewer.Preview(IResource res,
IEditorService edSvc, String locale) in
162
at Maestro.Base.Editor.EditorContentBase.Preview() in
C:\projects\mapguide-maestro\Maestro.Base\Editor\EditorContentBase.cs:line
376
at Maestro.Base.Commands.PreviewResourceCommand.Run() in
C:\projects\mapguide-maestro\Maestro.Base\Commands\PreviewResourceCommand.cs:line
42
at ICSharpCode.Core.WinForms.ToolBarCommand.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e,
ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e,
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons
button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
IntPtr wparam, IntPtr lparam)/
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-Maestro-6-0M6-available-tp5306454p5306565.html
