[mapguide-users] Ajax viewer, URL in Properties Pane
Gord McKenzie gord.mckenzie at canam.com
Mon Feb 6 11:04:02 PST 2017
OK. That code solution fits my scenario.  When I paste these two functions into "propertyctrl.templ", replacing the original versions, my map viewer window freezes up.  I imagine there is a problem properly loading the propertyctrl.templ file and it freezes the map window load.
-----Original Message-----
From: mapguide-users [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of RenoSun
Sent: Monday, February 06, 2017 10:43 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Ajax viewer, URL in Properties Pane
No problem. The solution for Ajax viewer is similar. Please modify the following codes.
C:\Program Files\MapGuide\www\viewerfiles\propertyctrl.templ
function SetProperties(count, properties) {
    var code;
    propCount = count;
    if(count != 1)
        var text;
        if(count == 0)
            text = "__#PROPERTIESNONE#__";
            GetMapFrame().SetPropertyPaneToolbarVisibility(false);
        else
            text = GetMainFrame().FormatMessage("__#PROPERTIESITEMSEL#__",
new Array(count, "unused"));
            GetMapFrame().SetPropertyPaneToolbarVisibility(true);
        code = '
' + text + '
    else
        code = '
 __#PROPERTIESNAME#__		 __#PROPERTIESVALUE#__';
        for(var i=0; i < properties.length; i++)
            code += '
 ' + properties[i].name + '		' + HtmlDecode(properties[i].value) + '';
        code += '
    SetContent(code);
var _el = null; //Our "parser" element
function HtmlDecode(input)
    if (input == null || input == "")
        return input;
    if (_el == null)
        _el = document.createElement('div');
    _el.innerHTML = input;
    return _el.childNodes[0].nodeValue;
View this message in context: http://osgeo-org.1560.x6.nabble.com/Ajax-viewer-URL-in-Properties-Pane-tp5306236p5306550.html
mapguide-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapguide-users
