[mapguide-users] mapguide-react-layout 0.7 released
Kajar kajar.kuldsepp at gmail.com
Tue Feb 7 12:59:46 PST 2017
I have made lot of research related this issue I'm experiencing and found
that Studio is not breaking layout for react but issue is related to map
definition. When creating map with Studio and set map extent using "use
current map zoom to set these coordinates" and then use this  map and react
layout then layer is not fully visible. Even  if  layer in Studio map
preview seems fully visible is not correctly visible using react layout.
When you use same map which was previously  created by Studio and use
Maestro to create new extent for map and save the map, then layer is
So Studio map view extent generation causing some error for react layout.
I added also package I made for better understand the problem.
Some explanation using package:
Studio_map_false: this is map created with Studio and added extents for map.
Studio_map_true: this is fixed map( new extent for map) by Maestro.
Studio_flex_true: layout created with Studio using map
definition(Studio_map_true) which works with react.
Studio_flex_false: layout created with Studio using map
definition(Studio_map_false) which is causing faulty layer visibility with
react.
Studio_react_issue.mgp
<http://osgeo-org.1560.x6.nabble.com/file/n5306817/Studio_react_issue.mgp>
Kajar
View this message in context: http://osgeo-org.1560.x6.nabble.com/mapguide-react-layout-0-7-released-tp5301769p5306817.html
