[mapguide-users] MS SQL Server Spatial Provider - Unable to Connect
Greg gbneff at cid.utah.gov
Thu Feb 16 12:06:54 PST 2017
Using Maestro ver 6.0.0.63 I am unable to connect to a MS SQL Server database
on a remote server.  I am able to connect to a copy of the database on the
localhost.  The error in Maestro is "The remote server returned an error:
(559) MgFdoException". I am able to connect to the remote database using
SqlSpatialTools build 3759 and query the table with spatial data.  The
remote version is running on the default instance of sql server.  Using the
same credentials for all connections.  Also tried with sa credentials and it
still didn't work.  Log entry (shown below) says Native Client 10.0
required.  Native Client 10.0 is installed on both the local and remote sql
servers.
Remote Server
Windows Server 2008 R2
MS SQL Server Standard Edition (64-bit) v 10.50.6000 SP3 (2008 R2)
Mapguide OS 3.1 (64bit)
Locahost
Windows 10
MS SQL Server Express Edition with Advanced Services (64-bit) v 10.50.4042
SP2
The Mapguide server logs the following error:
<2017-02-16T12:35:29> 	2400	MapGuide Maestro v6.0.0.63	10.0.0.128	greg
 Error: An exception occurred in FDO component.
        Error occurred in Feature Source
(Session:54099516-f47e-11e6-8000-90b11c34bb0b_en_MTI3LjAuMC4x0AFC0AFB0AFA//0479af0e-fb2f-437f-a5b3-5d603d362f26.FeatureSource):
        Please install 'SQL Server Native Client 10.0' or upper to be able
to use the provider
        - MgFdoConnectionManager.Open() line 333 file
c:\working\build_area\mapguide\3.1.0\x64\mgdev\server\src\common\manager\FdoConnectionManager.cpp
        - MgFdoConnectionManager.CacheFdoConnection() line 1097 file
        - MgFdoConnectionManager.Open() line 1089 file
         (Cause: , Root Cause: )
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation() line 83 file
c:\working\build_area\mapguide\3.1.0\x64\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
  - MgOpTestFeatureSourceConnection.Execute() line 100 file
c:\working\build_area\mapguide\3.1.0\x64\mgdev\server\src\services\feature\OpTestFeatureSourceConnection.cpp
  - MgServerFeatureService.TestConnection() line 244 file
c:\working\build_area\mapguide\3.1.0\x64\mgdev\server\src\services\feature\ServerFeatureService.cpp
  - MgFdoConnectionManager.Open() line 366 file
View this message in context: http://osgeo-org.1560.x6.nabble.com/MS-SQL-Server-Spatial-Provider-Unable-to-Connect-tp5308288.html
