[mapguide-users] 30 seconds delay after creating +/-100 CreateRuntimeMap calls
Jackie Ng
jumpinjackie at gmail.com
Tue Feb 28 15:34:57 PST 2017
If you ran CREATERUNTIMEMAP many times on the same map definition and same
set of parameters, the only difference in the responses you get back are the
session ids. Thus the caching opportunity is to save the rest of the XML
response as a cached "template" and for subsequent requests of the same map
and parameters, just fetch the stored template, plug in the new session id,
make the new MgMap/MgSelection in that session's repository and return that
plugged in XML response.
Still, I don't think this is the actual problem at hand. It might be a bit
slow on some big map definitions, but not "30 seconds" slow.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/30-seconds-delay-after-creating-100-CreateRuntimeMap-calls-tp5309691p5310028.html
