[mapguide-users] Mapguide 3.1 Label Issue
Hans Milling
hm at geograf.dk
Sun Jan 1 23:40:40 PST 2017
When you say the rendering doesn't happen, do you get an error when executing
your C# code?
Is the label a complex one (using expressions) or a simple value from a
column?
Does the MapGuide error.log file has any errors when you try to render the
map image with labels?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-3-1-Label-Issue-tp5301253p5301735.html
