[mapguide-users] DbEnv::open: DB_RUNRECOVERY: Fatal error,	run database recovery
    Fritz Robert
    Robert.Fritz at win.ch
    Tue Jan 17 03:14:15 PST 2017
since updating from 2013 to 2017 we see lots of the following error message:
Error: An exception occurred in DB component.
AIMS doesnt response for some time (minutes) and our system is down.
It does happen once or twice a day.
It did not happen with AIMS 2013.
We have two nearly identical servers and installations (including repository) - it happens on both.
We have changed nearly all settings in serverconfig.ini but to no avail.
When it happens I cant see any pattern - load is not higher then at other times.
What is the reason for the message?
What can I do to avoid this message?
Many thanks, Rob
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20170117/b1093c0b/attachment.html>
