[mapguide-users] Mapguide WKT standards?
Patrik Johansson
mapguide at morkl.se
Wed Jan 18 07:21:16 PST 2017
Seems like either Nabble or the mailing list ate my Oracle view
example. Here it is again:
CREATE OR REPLACE VIEW MY_VIEW_DENSIFIED AS
SELECT ID, SDO_GEOM.SDO_ARC_DENSIFY(t.GEOM, m.DIMINFO,
'arc_tolerance=0.01 unit=m') as GEOM
FROM MY_VIEW t, ALL_SDO_GEOM_METADATA m WHERE m.TABLE_NAME = 'MY_VIEW'
AND m.OWNER = 'MY_SCHEMA'
Cheers,
Patrik Johansson
On Wed, Jan 18, 2017 at 4:13 PM, morkl <mapguide at morkl.se> wrote:
> Just a thought: Have you tried creating a buffer with distance 0?
> I haven't tried it myself, because whenever I've had troubles with
> CurvePolygons I've been using the Maestro SDK, which fails before you have a
> chance to create a buffer.
> If the data is stored in a database, you might be able to create a view that
> generates regular polygons.
> This is the pattern I've used for Oracle views in the past:
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-WKT-standards-tp5303869p5303878.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
