[mapguide-users] Problems with base layers.
Henning van Wyk
henning.vw at icloud.com
Fri Jul 14 01:02:03 PDT 2017
Good Day Gordon,
No have not found a way around it.
I see the township layer works but none of the other like erf size, house nr, erf nr.
Also if you select arial image you cannot use the search function with layers.
Thank you for the feedback.
Regards,
Henning
> On 13 Jul 2017, at 3:11 PM, GordonL <gordon.luckett at arrowgeomatics.com> wrote:
> Yes, this is common, especially when you combine Base Layers with Tiled
> Layers.
> Have you found a work-around yet?
> I am looking to re-work the OpenLayers layers (visible and display order) to
> work around this bug ...
> gordon
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-with-base-layers-tp5298092p5327781.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
