[mapguide-users] Set selection color using MaestroAPI 6
Jackie Ng
jumpinjackie at gmail.com
Tue Jun 13 10:21:27 PDT 2017
Please be more specific about what you mean by loading a shapefile.
Did you create a Feature Source using the SHP provider?
If so, did you add your SHP file and its dbf/prj/shx/etc files and marked
the SHP file as the active file? At this point, you should have a valid SHP
feature source, which you can then create Layer Definitions from.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Set-selection-color-using-MaestroAPI-6-tp5322623p5324065.html
