[mapguide-users] Help on React template
Jackie Ng jumpinjackie at gmail.com
Mon Jun 19 01:54:28 PDT 2017
I'm curious what you're actually doing because custom templates and
components is a use case only supported by the [custom viewer bundle using
the npm module] and not the standard bundle.
Unless you are using a different definition of component from mine (which is
a React component that uses modules/components provided by the npm module)
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Help-on-React-template-tp5324579p5324634.html
