[mapguide-users] Coordinate System Overrides
Jackie Ng jumpinjackie at gmail.com
Tue Jun 27 23:26:38 PDT 2017
Coordinate System Overrides is a slight misnomer.
What you're actually overriding is the declaration of what the coordinates
in OracleSrid4326 and OracleSrid8307 represent. You are not transforming
anything by changing the coordinate system here.
Coordinate System Overrides is you telling MapGuide: If you see data from
this Feature Source in OracleSrid4326, I want you to treat any data as
though it were in the coordinate system of <your selected coord sys WKT>
So to then answer your actual question. The coordinate system declared in
your Map Definition is the actual source of truth. Any layer -> feature
source whose coordinate system does not match the one in the map def is
automatically reprojected by MapGuide.
So what you really want (for your data to line up with OSM), is to have a
Map Definition in WGS84.PseudoMercator (EPSG:3857). MapGuide will reproject
any data from layers/featuresources in that map def that don't have the same
CS as the one you declared on the map def.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Coordinate-System-Overrides-tp5325772p5325784.html
