[mapguide-users] react-layout: Hooking to events in the AJAX viewer (OnSelectionChanged)
Jackie Ng jumpinjackie at gmail.com
Thu Mar 2 00:12:00 PST 2017
You raise an interesting point about how our viewer offerings are being used.
Namely, I wasn't expecting embedding the viewer in a frame/iframe to feature
prominently as a common use case. The viewer API design thus far has been
going on the assumption that the react viewer is either the top-level
element or a sibling of top-level content.
So my current answer is: No not possible, but this is clearly something that
will need to be supported in some form so that migrating from Fusion is not
too painful.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/react-layout-Hooking-to-events-in-the-AJAX-viewer-OnSelectionChanged-tp5309934p5310244.html
