[mapguide-users] Updating Feature Sources without restarting MG
Reservoirdog c.schmidt at relis.ch
Tue May 9 05:03:33 PDT 2017
In our company we pretty often update geodata, mainly in form of
SQLite-Files.
So, if e.g. a water-utility is being updated we write a new sqlite-file and
replace the old
one in the repository. If I try to preview the "new" data now, it looks
corrupt.
It only works immediately if the filename is other that the old, or Mapguide
service gets restarted.
In MG 2.6 it was sufficient to save the feature source again, and it showed
the correct "new" data.
Is there any way I can replace sqlite-files while leaving mapguide running
and don't have to rename filenames? I would like to sort of "update" a
feature-source via Maestro or Mapagent...
How do other users handle this "data-update-issue"?
best regards, Chris.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Updating-Feature-Sources-without-restarting-MG-tp5319874.html
