[mapguide-users] Updating Feature Sources without restarting MG
Martin Morrison
martin.morrison at edsi.com
Wed May 10 05:21:32 PDT 2017
SQL server (or Oracle) would be the option I would pick. Updates on the fly and a true RDBMS. Speed should not be an issue with it.
Martin Morrison
Infrastructure Application Engineer/Systems Analyst
Engineering Design Systems, Inc.
540.345.1410
www.edsi.com
-----Original Message-----
From: mapguide-users [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Reservoirdog
Sent: Wednesday, May 10, 2017 7:08 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Updating Feature Sources without restarting MG
thx guys for your inputs.
@Jackie, I have to stick to SQLite because of its performance-benefits.
Up to 200MB size, there's quite nothing as fast as (Spatial) SQLites.
Where can I check if SQLite is excluded from Connection Pooling?
Also what I see often, is if I replace a SQLite-File, I cannot see any Schema-Changes e.g. when modifying a layer. So it seems, also schema-definition of the SQLites are somehow cached.
Also here, restart of Mapguide or renaming the file to a new filename fixes this.
@Kajar, thx for your hints. Unfortunately SHP is not a format, which can hold much attributive information, you also need one shapefile for each featureclass which gets unhandy when dealing with LARGE databases. My SQLites contain 100-200 feature classes.
Something needs to have changed in the SQLite-Provider, as with the old MG-Versions re-saving the Feature Source was sufficient.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Updating-Feature-Sources-without-restarting-MG-tp5319874p5320030.html
mapguide-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapguide-users
