[mapguide-users] TiledMapCacheSize
Tyler Simmons
tsimmons at atlasgeodata.com
Fri May 12 09:33:36 PDT 2017
Hello,
I have received error instructing me to increase TiledMapCacheSize in
serverconfig.ini:
The Tile Service map cache has been cleared. Please increase
TiledMapCacheSize in serverconfig.ini.
However, TiledMapCacheSize does not exist in serverconfig.ini. Is
this string located elsewhere, or called something different now? I
didn't see it in any of the other configuration settings. Perhaps I
need to manually add it to serverconfig.ini. If it needs to be
manually added, what value is default or suggested?
Thank you,
Tyler Simmons
This email and any files transmitted with it are confidential and intended
solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager
admin at atlasgeodata.com.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20170512/490c784c/attachment.html>
