[mapguide-users] Mapguide Tiles with OpenLayers
Jackie Ng jumpinjackie at gmail.com
Thu Nov 2 17:57:10 PDT 2017
If the tile set is using the "Default" provider, just take that example and
replace the Map Definition resource id with your tile set resource id. You
still need to manually calculate MPU, scales, etc.
If the tile set is using the "XYZ" provider, you can just use ol.source.XYZ
and set it up with the same url template string from your linked example
(make sure the {x}, {y} and {z} placeholders are still there)
- Jackie
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
