[mapguide-users] Fusion - If Using Any of Google Base Maps - Cursor Will Be Off (Hover/Select) - AIMS2017
GordonL
gordon.luckett at arrowgeomatics.com
Mon Nov 27 07:52:14 PST 2017
I had a weird situation where if I hid the Overview widget programatically
before it completely loaded, it would offset the cursor.
What I ended up doing is running the following command in a timeout when the
map first loads:
Fusion.getMapById('Map').oMapOL.updateSize();
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
