[mapguide-users] Support Sqlserver 2016 inPASS mode
Hans Milling hm at geograf.dk
Thu Sep 21 02:50:21 PDT 2017
MapGuide or FDO used to have a bug, where it tried to read information about
all databases on the server, even the databases that the user have no access
to. This resulted in an error. Solution was to use a user on the database
server that had access to everything (the sa user) to create the feature
source, and then change the username/password to the correct user, after the
datasource were created.
I am not sure if you experience the same?
Best regards
  Hans Milling...
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
