[mapguide-users] Migration Autodesk to Esri
Martin Morrison
martin.morrison at edsi.com
Wed Apr 4 11:06:59 PDT 2018
I really want to stand and clap. Below is the truth...
Martin Morrison
Infrastructure Application Engineer/Systems Analyst
Engineering Design Systems, Inc.
540.345.1410
-----Original Message-----
From: mapguide-users [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of GordonL
Sent: Wednesday, April 4, 2018 1:56 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Migration Autodesk to Esri
I really want to be a cynic and to tell management to stop using things like Google (open source) and basically most of the web running on Linux.
There would be a more of risk to management to move to a platform that is not as "open" as MGOS. However, the key to any thing is the DATA. Data is EVERYTHING.
So, if you do go with ArcGIS Server, for example, make sure your data is a format that all GISes can see. For example, most GIS systems can see SHP (not SDF).
But above all, the data should be stored in a database such as Oracle, SQL Server or PostgreSQL & PostGIS.
If you do store your data in a database, especially with ArcGIS Enterprise, make sure you are using the databases' native Geometry format and not ESRI Proprietary st geom.
Your life will be way easier.
If your data is in a neutral database, all GIS systems can view and edit the data (given permissions) and regardless of what comes down the pipe (Autodesk/ESRI/Tesla/Amazon GIS) you are in a position to take advantage.
DATA is EVERYTHING.
gordon
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
mapguide-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapguide-users
