[mapguide-users] Incorrect numbers displayed when using Selection Panel mapguide 3.0
BMason
masonb12 at telus.net
Thu Apr 5 11:52:11 PDT 2018
Yes, I believe that I have solid steps for reproducing this problem. I have
tried several times. Just try it with any unmanaged shapefile as a data
resource. A new field is created using a calculation. You can see it by
using a preview of the data resource. But if you view the existing layer
for that data resource, the field does not exist. Also if you create a new
layer that points to the data resource, no attributes display. They are all
grayed out. Maybe I am doing something wrong. Please let me know if you
can use the round function and display the results in a new layer using an
unmanaged resource.
Brad
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
