[mapguide-users] Link to wiew widget coordinate transformation
Kajar
kajar.kuldsepp at gmail.com
Fri Dec 21 01:35:12 PST 2018
Is there a way to create coordinate override for "Link to view" widget.
My map using EPSG:3857 coordinate system.
I want to create Mapguide map links for point objects using those map extent
parameters: generate map extent using point coordinates, but my points are
in different coordinate system.
I know I can tranform my points to desired coords system, but if there a way
to use some tranforming for link to view widget.
Kajar
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
