[mapguide-users] MGTileSeeder Help
Crispin_at_Linknode crispin.hoult at linknode.co.uk
Sun Feb 4 01:51:51 PST 2018
Are you creating tiles from vector sources or rasters?
Not sure this will help, but there is a lot of load on the raster provider
on the server with tiling and so if you run the MGSERVER in interactive mode
(ie on Windows you would stop the service, start a CMD prompt and set the
GDAL debug variable to verbose (cant remember that syntax) then mggerver.exe
-interactive).
Some errors are not carried through to the logs but this may show more.  I
think MG 3.1.1 / 3.3 fixes an error propogation problem.
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
