[mapguide-users] MapGuide (actually FDO) 64-bit Linux blockers
Gabriele Monfardini gabrimonfa at gmail.com
Thu Feb 15 09:48:10 PST 2018
Dear Jackie,
we do care about MapGuide on 64-bit Linux.
We have some of them, even in production.
But we just use FDO OGR provider, with gdal compiled with PostgreSQL
support.
We're not using PostgreSQL provider since it need a connection per schema
instead of a connection per db.
We would need many more database connections and to create a lot of
datasources, which is not at all convenient for us.
Anyway we support your effort on this, and thank you for your work!
Best regards,
Gabriele Monfardini
On Thu, Feb 15, 2018 at 3:33 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> Hi All,
> In my MapGuide roadmap announcement I expressed my desire to hopefully see
> the "preview" label for MapGuide on 64-bit Linux removed for the next major
> release (3.3).
> The "preview" label has stuck for the longest time due to some major
> blockers in certain FDO providers. In the hopes of being able to pool in
> community effort and/or knowledge to solving this problem faster, I'm going
> to detail the blockers that currently lie in the following providers:
>  - SHP Provider
>  - PostgreSQL Provider
>  - King Oracle
> This is going to be super technical. Be warned.
> For the SHP Provider, the blocker is in the SHP spatial indexing code. It
> makes heavy use of the C++ "long" and "unsigned long" data types which is
> not portable across platform. sizeof(long) == 8 for 64-bit Linux, while
> sizeof(long) == 4 for every other platform we target. The incorrect size
> assumptions result in corrupted spatial queries which manifest as features
> from a SHP source "randomly" disappearing when queried. Another unrelated
> problem is that the SHP test suite currently has test failures on both
> Windows and Linux meaning we don't have an objective baseline for "it
> works". We should get the test suite back into a passing state first before
> being able to tackle this problem with confidence.
> For the PostgreSQL provider, the blocker is also due to use of "long" and
> "unsigned long" in the PostGISDriver code. I've partially fixed this
> (https://trac.osgeo.org/fdo/changeset/7621), so that the unit test suite
> at
> least runs to completion with test failures on 64-bit, instead of its
> previous behavior of segfaulting out due to incorrect size assumptions in
> the PostGISDriver. Now that the unit test suite runs, the majority of the
> failures are various overflow errors reported by libpq which once again I
> suspect is due to incorrect data type size assumptions. The "blocker"
> status
> can be removed from this provider when the unit test suite is all passing.
> For the King Oracle provider, I think it is (and has been) a complete
> non-starter on Linux. The provider code has built without errors against
> the
> Linux Oracle Instant Client SDK for the longest time, but admittedly I
> never
> actually tested this provider on Linux, so it's been a "use at your own
> risk" type deal for this provider (even on 32-bit linux). Has this provider
> ever worked for anyone on Linux? The key blocker I'm seeing here is mainly
> this *8 year old* issue (https://trac.osgeo.org/fdo/ticket/562). I'm not
> well versed with this particular provider (nor the OCI library), so my
> ability to tackle this problem head-on is limited unlike the other FDO
> providers. The lack of an easy to setup and run unit test suite on this
> provider also hampers development somewhat.
> So that is what I think are the blockers that prevent me from considering
> MapGuide on 64-bit Linux to be production-ready.
> Which is a shame, because a production-ready MapGuide on 64-bit Linux is a
> gateway to better docker containers (nobody does and should run 32-bit
> applications inside a docker container!), and the reason why the docker
> angle is of major interest to me is that we can start to explore some
> highly-scalable and load-balanced architectures that are possible with a
> reliable MapGuide docker container. But if half the FDO providers don't
> work
> properly, well ... there's isn't really much of a point.
> So there's my thoughts on the state of 64-bit Linux support for MapGuide.
> Thoughts? Insights? Do you even care about MapGuide working on 64-bit
> Linux?
> Sound off right here on this thread.
> - Jackie
> Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-
> f4182607.html
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20180215/ea19c824/attachment.html>
