[mapguide-users] Map Switch, Base Layer groups issue
madhurchanana madhurchanana92 at gmail.com
Tue Jan 2 00:46:34 PST 2018
Hi ,
I have created a fusion application with three map definitions, with two of
them containing Base Layer groups. When i switch map from a map definition
not containing base layer groups, it is able to hide all the current active
layers and switch to the other map definition.But when i switch from a map
definition containing Base Layer groups having any layer active, the layer
gets attached to the Openlayers layer below and becomes the new base layer
for the next map.
I want my Base Layers to automatically get unchecked when i switch my maps.
It works fine if all the layers are inactive and i change maps. how can i do
it by coding or making changes in existent code in MapMenu.js.
Thanks
Madhur
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
