[mapguide-users] Display Historical value assigned to a polygon
RenoSun renolionheart at gmail.com
Thu Jan 4 11:11:29 PST 2018
I agreed with Martin Morrison.
I will join two tables with PostgreSQL as one spatial view table.
If you would like to enable the selection for spatial view, you may check
out following link:
http://osgeo-org.1560.x6.nabble.com/SQL-Server-Spatial-View-Selection-Issue-td5228068.html
However, if you really dislike the large joint table...
I will develop a PHP, and ASP .NET etc. web page to query and display the
*State Power Load* table info based on the *State ID*.
Display the PHP/ASP .NET web page by map tip hyper link, opening the new
window, or task panel (Fusion).
Cheers!
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
