[mapguide-users] Display Historival value assigned to a polygon
Hans Milling
hm at geograf.dk
Fri Jan 5 00:02:17 PST 2018
I usually create a table that matches the view (with a primary key). Then I
add the FeatureSource pointing to the table. The feature source is created
with primary key and can be selected. Then I delete the table and create a
vire with the same name, and everything works.
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
