[mapguide-users] XYZ layer 500 (Internal Server Error)
RenoSun
renolionheart at gmail.com
Wed Jan 17 14:13:22 PST 2018
Hi All,
I have a problem to generate XYZ tiles with 500 error again.
The request looks like following URL:
https://maps.qualicumbeach.com/qbmap/rest/library/QualicumBeach/TiledMaps/UtilityTiledMap.MapDefinition/xyz/Base%20Layer%20Group/17/20227/44818/tile.png
The UtilityTiledMap is using coordinate system (WGS84.PseudoMercator (WGS84
based Mercator (spherical formulation))).
However, the mapguide-rest only generated the .lck files.
I am using Release 1.0 RC5.
I got following error from debug.log as following:
(11746) Checking if C:\Program Files\Autodesk\Autodesk Infrastructure Web
Server Extension
2017\www\rest/./cache/tile.png/QualicumBeach/TiledMaps/UtilityTiledMap/Base
Layer Group/17/20227/44818.png exists (11746) C:\Program
Files\Autodesk\Autodesk Infrastructure Web Server Extension
Layer Group/17/20227/44818.png does not exist. Locking for writing (11746)
Acquired lock for C:\Program Files\Autodesk\Autodesk Infrastructure Web
Server Extension
Layer Group/17/20227/44818.png. Checking if path exists again. (11746)
Rendering tile to C:\Program Files\Autodesk\Autodesk Infrastructure Web
Server Extension
Layer Group/17/20227/44818.png (11746) Going down old code path (11746) Calc
bounds from XYZ (11746) Releasing lock for C:\Program
Layer Group/17/20227/lock_44818.lck (11746) C:\Program
Server Extension
Server Extension
bounds from XYZ
Windows Server 2016 + AIMS2017 (env)
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
