[mapguide-users] MGOS in WinSrv 2016
Lisa Weber
lisaw at precisionmanagementsolutions.com.au
Tue Jan 30 13:17:51 PST 2018
Fabio,
I have been working to update a client from AIMS 2013 to MGOS 3.1 since November as there’s custom code and had some issues. Are you using IIS10? This proved too large a stumbling block and after much experimentation the decision was made to switch to Apache. Once that was done there have been no issues.
You could also try using one of your own SHP files to see if you’re able to save/validate a new layer rather than one of the samples.
Kind Regards,
Lisa
From: mapguide-users [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Posta Fabio GEOnWeb
Sent: Tuesday, 30 January 2018 7:57 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] MGOS in WinSrv 2016
Dear all,
we have installed MGOS on Windows Server 2016 and the only thing that doesn’t work is the Save/Validate of a layer.
This is the error that MG Maestro generate :
Validating resource: Session:c8df5afa-059a-11e8-8000-0050563d7cb4_en_MTI3LjAuMC4x0AFC0AFB0AFA//1adc1249-064c-4529-b707-1d7eea6b677b.LayerDefinition
Error - Error_General_ValidationError: Failed in validator:
Errore del server remoto: (559) MgInvalidRepositoryTypeException.:
Invalid repository type.
- MgResourceServiceHandler.ProcessOperation() line 80 file c:\working\build_area\mapguide\3.1.0\x64\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
- MgOpGetResourceHeader.Execute() line 97 file c:\working\build_area\mapguide\3.1.0\x64\mgdev\server\src\services\resource\OpGetResourceHeader.cpp
- MgServerResourceService.GetResourceHeader() line 1241 file c:\working\build_area\mapguide\3.1.0\x64\mgdev\server\src\services\resource\ServerResourceService.cpp
We have already spent a couple of days without result ... :(
Do you have any suggestions to give us?
Thank you so much,
Fabio Rizzato
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20180131/3df6c80b/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20180131/3df6c80b/attachment.png>
