[mapguide-users] MapGuide Maestro 6.0M9 available
BMason masonb12 at telus.net
Mon May 14 08:19:56 PDT 2018
Hi Jackie,  is it possible to edit records using the selection panel?
Enhanced viewing of data using the view selection panel is great,  but being
able to edit and add records would be even better.  If this is possible,
could you provide a some screen shots with an example?   thanks
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
