[mapguide-users] Configuration for PostGIS raster
Gabriele Monfardini
monfardini at ldpgis.it
Wed Oct 3 09:19:27 PDT 2018
On Wed, Oct 3, 2018 at 2:50 PM Jackie Ng <jumpinjackie at gmail.com> wrote:
> Without knowing much about the GDAL provider internals, but assuming it
> uses
> GDAL in the same way the OGR provider uses OGR, then I would assume the
> DefaultRasterFileLocation property is not necessarily a physical file path,
> but rather is actually just an arbitrary data source string and going by
> that logic you would set DefaultRasterFileLocation to something like:
> PG:host=localhost port=5432 dbname='mydb' user='postgres' password='secret'
> schema='public' table=mytable
thank you Jackie, it workish, it does not give any error, it founds that
there is a raster but nothing is displayed if used in a map.
I will keep investigating.
Regars,
Gabriele
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20181003/dda0eac6/attachment.html>
