[mapguide-users] mapAgentURL is not defined in FUSION mapguide
Rodolfo Moreno
rodolfoamoreno at gmail.com
Mon Aug 5 06:38:11 PDT 2019
Thanks Liglio,
I made what you suggested.
_____________________________________________________
var getSiteVersion = function(sessionId, callback) {
var xhr = getXmlHttpRequest();
* var mapAgentUrl = getAgentUrl();*
xhr.open("GET", mapAgentUrl +
"?OPERATION=GETSITEVERSION&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&SESSION="+
sessionId, true);
__________________________________________________________
And now fusion is launched another error:
Error Details:
Uncaught TypeError: callback is not a function
Stack Trace:
- ? at http://localhost/mapguide/fusion/lib/fusionSF.js (line: 1698)
here the code in that line:
var getAgentUrl = function(callback) {
* if the application has been loaded from the same host as
* fusion is installed in, then technically we don't need to
* use the redirect script because we conform to the
* Same Origin Policy for XmlHttpRequest to work.
var fusionURL = Fusion._getScriptLocation();
var testUrl = window.location.protocol + '//' +
window.location.host;
var configUrl = 'config.json';
if (((Fusion.fusionURL.indexOf("http://") < 0) ||
(Fusion.fusionURL.indexOf(testUrl, 0) == 0)) && !(Fusion.bForceRedirect)) {
Fusion.sRedirectScript = '';
else {
Fusion.sRedirectScript = 'redirect.php';
configUrl += '&method=get';
var r = Fusion.getRedirectScript();
if (r != '') {
r = r + '?s=';
var fusionURL = r + Fusion.getFusionURL() + configUrl;
xhr.open("GET", fusionURL, true);
xhr.onload = function (e) {
if (xhr.readyState === 4) {
if (xhr.status === 200) {
//Can't use parseJSON as this JSON file will most likely
have comments
eval("Fusion.configuration=" + xhr.responseText);
var s = Fusion.configuration.mapguide.webTierUrl;
/* if it is set, use it ... otherwise assume fusion is
installed in
* the default location and compute the web tier url from
that
if (s) {
var nLength = s.length;
var slastChar = s.charAt((nLength - 1));
if (slastChar != '/') {
s = s + "/";
} else {
var idx = Fusion.fusionURL.lastIndexOf('fusion');
if (idx == -1) {
s = Fusion.fusionURL + "../"; //loaded
relatively from within fusion directory
else {
s = Fusion.fusionURL.substring(0, idx);
Fusion.configuration.mapguide.mapAgentUrl = s +
'mapagent/mapagent.fcgi';
* callback(Fusion.configuration.mapguide.mapAgentUrl);*
(LINE 1698)
} else {
console.error(xhr.statusText);
xhr.onerror = function (e) {
xhr.send(null);
___________________________________________________________________
what could be the problem?
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
