[mapguide-users] Missing required parameter: ApplicationDefinition
RenoSun renolionheart at gmail.com
Mon Aug 12 13:08:28 PDT 2019
I noticed some wired error using Maestro creating fusion/flexible layout. You
need to manually making sure the preview URL is correct.
https://yoursite/mapguide/fusion/templates/mapguide/index.php?template=limegold?ApplicationDefinition=Library://QualicumBeach/FlexibleLayouts/Property.ApplicationDefinition&locale=en
It has two "?" for URL parameters, but it should only be "?" for the first
URL parameter, and using & for the rest URL parameter such as
APplicationDefinition.
https://yoursite/mapguide/fusion/templates/mapguide/index.php?template=limegold&ApplicationDefinition=Library://QualicumBeach/FlexibleLayouts/Property.ApplicationDefinition&locale=en
Hope this help you!
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
