[mapguide-users] Map not loading after upgrade
Martin Morrison martin.morrison at edsi.com
Tue Aug 13 07:09:44 PDT 2019
Look in the providers.xml file and make sure the OGR.dll is in the correct path.
MapGuide\Server\Fdo\providers.xml
Martin Morrison
Application Engineer
Main Office: 540-345-1410 Toll Free: 888-355-0081
Products ǀ Training ǀ Service ǀ Tech Support
Please visit microcad3d.com for more information!
-----Original Message-----
From: mapguide-users <mapguide-users-bounces at lists.osgeo.org> On Behalf Of maabas
Sent: Tuesday, August 13, 2019 8:59 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Map not loading after upgrade
Thanks Jackie for replying. I fixed the problem yesterday by digging from step 1 (feature sources) and found out that OGR.dll could not be located.
This is kinda weird because every mapguide version I used never hard problems with OGR which I use for importing mapinfo tab files. However it is solved by converting the tab files into SHP files (fortunately MGOS 3.1.2 doesn't have problems with SHP fdo) and rebuilding it from there. I tried reinstalling MGOS 3.1.2 since OGR is not working but still the same. So for now I will continue with SHP files.
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
mapguide-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapguide-users
