[mapguide-users] Exception when setting layer Visibility
frieda
ruslankutowoj at web.de
Wed Feb 6 01:04:39 PST 2019
Hello, I need help to understand the purpose of the following codeblock.
I have MapGuide Server 2.5.2 Final installed on IIS in Windows 10 64 bit.
The function is for printing the map in pdf or word document.
Private Sub printButton_Click(ByVal sender As Object, ByVal e As EventArgs)
Handles btnPrint.Click
Dim objUtilties As New
CCommonFunctions(Request.ServerVariables("SCRIPT_NAME"))
If Not m_objMGC.IsPlotBoxDrawn(m_objMapGuide) Then
AddJavaScript("Print", "alert('No Plotbox');")
Exit Sub
End If
Dim changedLayers As ArrayList = PrepareMapForPrinting()
Try
Scale = DetermineScale(Me.cboScale.SelectedValue)
Dim ViewScale As Double = Scale
If Me.cboScale.SelectedValue.Contains("current") Then
Scale /= ScaleDistortion
End If
Dim DPI As Integer =
g_objObjHandl.NZ_Int(Me.cboDPI.SelectedValue)
Dim objMapDraw As New MapGuideDrawing(m_objUser,
m_objUser.Project.DocumentFolder)
objMapDraw.DPI = DPI
objMapDraw.RegKeyPath = Application("APP_REG_PATH")
Dim MapSize() As Double =
objMapDraw.DetermineMapExtent(Me.cboPageSize.SelectedValue,
Me.rbQuer.Checked, 0.90000000000000002)
objMapDraw.InitializeMapImage(m_objMapGuide,
m_objMGC.GetPlotBox(m_objMapGuide, "(TYPE=1)", False), MapSize(0),
MapSize(1))
objMapDraw.InitializeLegendImage(m_objMapGuide,
Session("PRINTOPT")(0))
Dim MergedImage As Drawing.Image =
objMapDraw.MergeImages(m_objMapGuide.Map.Name, ViewScale,
g_objObjHandl.NZ_Boolean(Me.hdfLegend.Value), Session("PRINTOPT"))
Dim fileDir As String = objMapDraw.CreateDocument(m_objMapGuide,
MergedImage, Me.cboPageSize.SelectedValue, Me.rbQuer.Checked,
Me.cboDownload.SelectedValue)
objUtilties.DownloadFile(Me.Form, fileDir)
Catch ex As Exception
m_objUser.WriteError(ex, "")
AddJavaScript("PrintError", "alert('" & ex.Message & "');")
Finally
If changedLayers Is Nothing = False Then
RepairMapAfterPrinting(changedLayers)
End Try
End Sub
I get an Exception in the "RepairMapAfterPrinting"
Sub RepairMapAfterPrinting(ByVal pv_arrChangedLayers As ArrayList)
Dim Visibility As Boolean
Dim objMapGuide As FRIEDAcom.MapGuide = CType(m_objMapGuide,
FRIEDAcom.MapGuide)
objMapGuide.ConnectMapGuide(objMapGuide.SessionID,
Session("GRAPHIC").Project)
For Each layer As OSGeo.MapGuide.MgLayer In pv_arrChangedLayers
Visibility = layer.IsVisible()
layer.SetVisible(Not Visibility)
Next
End Sub
The Exception occurs here: Visibility = layer.IsVisible(). When I change it
to Visibility = layer.GetVisible(), the exception occurs in
layer.SetVisible(Not Visibility).
It's not my code and I don't really understand what's going on.
The Exception:
OSGeo.MapGuide.SWIGExceptionHelper.ThrowCustomException(String className,
IntPtr cptr) +494
OSGeo.MapGuide.PlatformBaseApiPINVOKE.MgLayerBase_SetVisible(IntPtr
jarg1, Boolean jarg2) +0
OSGeo.MapGuide.MgLayerBase.SetVisible(Boolean visible) +13
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
