[mapguide-users] Link to wiew widget coordinate transformation
GordonL gordon.luckett at arrowgeomatics.com
Wed Jan 2 08:41:45 PST 2019
The Link to View should inherit the Map Coordinate System.  For example, if
you are using 3857, your coordinates should show that, for example:
http://localhost/mapguide/fusion/templates/mapguide/index.php?template=maroon
&ApplicationDefinition=Library://Samples/Sheboygan/FlexibleLayouts/Aqua.ApplicationDefinition
&extent=*-9766188.325529%2C5423870.535598%2C-9765521.029637%2C5424415.613731*
&theme=Library%3A%2F%2FSamples%2FSheboygan%2FMaps%2FSheboyganGoogle.MapDefinition
&showlayers=&hidelayers=&showgroups=&hidegroups=&layerType=XYZ
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
