[mapguide-users] Update legend information on runtime
Jackie Ng
jumpinjackie at gmail.com
Wed Jan 30 04:33:13 PST 2019
864 layers !!!??? o_O
If you want to avoid a full legend rebuild, then your shortcut functions
that do the layer/group toggling should return some kind of changeset JSON
structure that the legend widget can use to update affected parts.
So just to spitball an example from your sample server-side code, you could
return a JSON structure like this:
"show": {
"layers": [<list of object ids of layers to set visible>],
"groups": [<list of object ids of groups to set visible>]
"hide": {
"layers": [<list of object ids of layers to set hidden>],
"groups": [<list of object ids of layers to set hidden>]
You'd then have to modify the legend widget so that you can pass this
structure to it, and using this information, update the widget's internal
representation of your map's layer/group data to match.
- Jackie
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
