[mapguide-users] mapAgentURL is not defined in FUSION mapguide
Rodolfo Moreno rodolfoamoreno at gmail.com
Tue Jul 23 06:47:37 PDT 2019
Hi Reno, thanks for your response
- "When you use .NET to display fusion with iframe, you no longer need to
send session id"
I am not using iframe with fusion
- "please double check if using SSL/non-SSL affect this as well"
I am not using SSL
- "make sure you assign proper role to the mapguide user that you use to
load fusion"
I am loading the fusion template from maestro. which must be the role to
mapguide user? Where must I specify this role?
by last, Is there some piece of code that I should modify in fusion.js or in
other files?
Thanks in advance
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
