[mapguide-users] WMTS GADL featuresource and layer?
Jamo
adam.jamison at portbris.com.au
Wed May 8 19:00:22 PDT 2019
I'm trying to add a WMTS featuresource via GDAL and then create a rasterlayer
to show it...
So far I've created the requierd GDAL_WMTS.xml file "test.xml" and loaded it
into the GDAL feature Source.
I can add the wmts within the react-sidebar viewer-mount and it works ...
but should the GDAL wmts also work using the above?
MapGuide Maestro 6.0.0.8587
MapGuide Opensource 3.0.0.8701
Fusion, PHP, Apache
Windows 7 Pro SP1
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
