[mapguide-users] MapGuide Server on a mobile device
RenoSun
renolionheart at gmail.com
Tue May 14 14:58:22 PDT 2019
Hi Frieda,
Yes, you should either use OpenLayers (OL) API 5.3.0 API to load your
mapguide map.
(https://openlayers.org/en/latest/examples/mapguide-untiled.html?q=mapguide)
Or upgrade Kaliopa Mobile Viewer
(https://github.com/sreckolipovsek/KaliopaMobileViewer) to OL 5.3.0 and to
match the latest MapGuide API (some c# codes need to be changed) +
sidebar-v2 (https://github.com/Turbo87/sidebar-v2) <require a lot of coding
efforts>
Real life example: TQB Public Mapping & GIS
<https://maps.qualicumbeach.com/qbmap/mobileMapViewer/MobileMap.aspx?m=Property>
I believe the easiest way is to use mapguide-react-layout
https://github.com/jumpinjackie/mapguide-react-layout Sidebar template :)
However, if you have FME Workbench made by Safe Software, you can easily
convert the SHP files into KML/KMZ format to ask your user to install Google
Earth on their Android phones/tablets to view those polygons.
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
